16 years agoVhdl code for IP_IRQ component!
Hi, I need help for Vhdl code for designing one IP component, small device drivers and test demonstration that give a periodic interrupt to sierra every second. "SEE ATTACHMENT" Com...
16 years agoa couple of things:
dont use std_logic_unsigned/signed/arith at the same time as ieee.numeric_std. I recommend using numeric_std. you cant compare a std_logic vector to a integer literal, you have to compare it to a string. For a hex string you need to write x"5e7". A std_logic_vector is NOT an integer, its a collection of bits.
