16 years ago[vhdl] artificial neural network
I'm interested in neural networks currently :) I've written some basic ANN implementation in java with ADELINE neurons. (Actually, this is only the background of the problem) I'd like to write a simple neuron in vhdl. input vector is multiplied by weigths, result is sum. If result is > 0 then output = -1 else output = 1 And here comes the problem, I have to multiply input values by weights which are real values. I know that vhdl supports real variables but how should I use it?:confused: I tried like that but it isn't correct code --- Quote Start --- variable weigth:real; variable tmp:real; weight:=0.1; for i in 0 to inputvector'length - 1 loop tmp:=tmp+(weigth*inputvector(i)); end loop; --- Quote End --- I'd be very gradefull for any help!12 Replies
Can Anybody provide me some workable examples of ANN in VHDL (or Verilog) -- and its description if possible, code in c , java, or structural scheme --for exploring the pecularities of its design as the simple code maybe not enough, but the code itself would be also valuable.
What are you trying to acheive with VHDL. VHDL has the real type for modelling and simulation only - you cannot synthesise them and put them on hardware/FPGA. you have to use std_logic_vector/unsigned/signed/fixed point. Floating point always has to be represented by vectors. The real type is NOT a vector.
If you are using VHDL solely to produce a model, then it is fine, but if you do not intend to put anything onto and FPGA, Id stick to java.
