16 years ago[vhdl] artificial neural network
Hello, I'm interested in neural networks currently :) I've written some basic ANN implementation in java with ADELINE neurons. (Actually, this is only the background of the problem) I'd lik...
16 years agoWhat are you trying to acheive with VHDL. VHDL has the real type for modelling and simulation only - you cannot synthesise them and put them on hardware/FPGA. you have to use std_logic_vector/unsigned/signed/fixed point. Floating point always has to be represented by vectors. The real type is NOT a vector.
If you are using VHDL solely to produce a model, then it is fine, but if you do not intend to put anything onto and FPGA, Id stick to java.
