16 years ago
[vhdl] artificial neural network
I'm interested in neural networks currently :)
I've written some basic ANN implementation in java with ADELINE neurons. (Actually, this is only the background of the problem)
I'd like to write a simple neuron in vhdl.
input vector is multiplied by weigths, result is sum. If result is > 0 then output = -1 else output = 1
And here comes the problem,
I have to multiply input values by weights which are real values.
I know that vhdl supports real variables but how should I use it?:confused:
I tried like that but it isn't correct code
--- Quote Start ---
variable weigth:real;
variable tmp:real;
weight:=0.1;
for i in 0 to inputvector'length - 1 loop
tmp:=tmp+(weigth*inputvector(i));
end loop;
--- Quote End ---
I'd be very gradefull for any help!
    I would like to know what is difference between LAbview FPGA (it seems alos generate the code in altera) simulation and Altera simulations in Verilog or VHDL?
    I have the diagram in Simulink so I have relating question --what is the most actual forums and discussion board on Simulink and especially Micro-cap, as the last one is very seldom in internet. And concerning the Microcap--could I use some conveter to or from Micro-cap to another environments such as Altera, Simulink and so on?
