16 years agoVHDL - CASE related question
Hello, This is probably a very fundamental question but I'm a little confused as I am new to this. In VHDL (I'm sure it the same for others too), if I have such a PROCESS: PROC...
16 years ago --- Quote Start --- an FPGA has no instructions, only logic gates and registers, so thats not a correct question to ask. You could write a CPU using VHDL and then you could ask your question about your CPU, not the FPGA. --- Quote End --- Thank you Tricky! I get that now. When you compile it will create whatever we want in digital logic. So as long as there are enough of those parts I can do any amount of assignments inside. Thank you very much. Yes I do have a long way to go before I really start coding. Thank you for the help Tricky.
