16 years agoVHDL - CASE related question
Hello, This is probably a very fundamental question but I'm a little confused as I am new to this. In VHDL (I'm sure it the same for others too), if I have such a PROCESS: PROC...
16 years ago --- Quote Start --- About that VHDL is a not a programming language, I can understand that it is different from C++/Java/etc., in the sense that it is concurrent, synchronous, etc., but is there something important you need to keep in mind when writing VHDL? For someone new to VHDL and coming from a C++/Java background. Thank you. --- Quote End --- before even typing 1 letter of VHDL, first think about the circuit you want to create. As VHDL is a description language, not a programming language, you are only ever describing a circuit you already know. What confuses people is that you can do alot in VHDL that is very C++ like, but actually wont do anything for you when you compile it - alot of this functionality is there only for testing and modelling purposes (for example, I have functions that can read/write bitmap files) but is in no way synthesizable. If you keep to the first rule - you'll improve your VHDL massivly.
