16 years agoVGA IP component, connected to extern SRAM
Hi anybody.
I need help for designing “VGA IP component connected to extern SRAM “using Quartus II 9.1sp2 Web Edition, Nios II 9.1 IDE and DE2 boards. I have no idea which components to use for designing hardware architecture. I m beginner in FPGA’s pleas help me! It’s a university project and we also use University Program supported by Altera.4 Replies
hi everybody
I have designed the hardware part of vga but i don't have any idea about software part,i dont know what i should write for the c cods in niosll.it should print pixel and ASII on the monitor. thank you for helping - Altera_Forum
this link could be useful
http://www.alteraforum.com/forum/showthread.php?t=20085&highlight=vga anyway, If you want to perform video processing paths, you should try the video intelletual properties by Altera http://www.altera.com/literature/ug/ug_vip.pdf - Altera_Forum
I have to use vga cable that is connected with DE2 board and to make it work.I'm not sure what the output should be.the only thing i know i have to design hardware and software to make vga cable work.my problem is i don't know which components should be used in sopc builder.i know i have to add in the builder cpu,jtag,SRAM,vga component and onchip memory but i don't know should i add the pixel_buffer,character buffer,.....
i would like to know what the sopc builder overview should look like. thanks for helping me - Altera_Forum
Hi
I did not understand at all your problem: you would like to create a VGA component (a controller I suppose?) or you would like to use existing components from VIP to create a video pipeline? I suggest yout to take a look here http://www.altera.com/literature/an/an427.pdf, an application note provided by altera about VIP. There are also lots of thread on this forum about video pipelines, a fast search should give lots of results.
