very noisy outputs on EPM3064
Without seeing your schematic and PCB layout it is hard to make any significant comments. That being said:
What does your input clock signal look like? Is it monotonic with no noise?
Can you zoom in on a transition on the data? Interesting to see what an output transition looks like in detail.
What does the power rail look like, wrt noise?
I have multiple EPM7064S and EPM3064A parts on boards (using PLCC packaging) and don't see such issues.
- Niko33 years ago
You can find the schematic and the layout in the attachment.
In the layout I planned to use a socket for the EPM3064 chip. I found a small one in the internet, but it does not meet the specified dimensions of a TQFP44 chip. With the socket the chip cannot be programmed at all.
Therefore I made a second version with the chip soldered directly on the board. For the tests I only mounted the chip, the JTAG socket, the 4 blocking capacitors and some pins for power supply and input/outputs.
The layout is shown in a version with highlighted ground and VCC.
