17 years agoverilog test code issue
file://localhost/C:/Documents%20and%20Settings/aabelian/Desktop/altera_sim.JPG Hi to all,
This is my first post. sorry if any thing I am doing wrong. I am new to verilog but I am long time C user. I tried my first code today. Using simulator I see delay on output side and clk pulse doesn't work. I am having hard time to understand what am I doing wrong. any help will appreciate. thanks Andre module led_test(sw1,led1,clk); input sw1; output led1; output clk; reg led1,led2,clk; // initial begin led1 <= 0; end always@(sw1 ) begin # 500 clk = ~clk; end always@(sw1 ) begin if(sw1 == 1) led1 <= 1; else led1 <= 0; end endmodule6 Replies
Look,
sorry I was in bad mood. do not want to help? that's fine. I can't wait to see how much do you know about HDL and I will remind you one day when you ask a question? thanks - Altera_Forum
OK,crap,you don't even want to refer to a book,I promise no one will reply to your question!
This is your second replay with crap. Stop replaying I do not need your feedback.
sorry to say you don't understand the difference between code for synthesis and code for testbench,so don't try to write one before you really understand!
I am reading and I am trying to understand.
Do you know the reason? thanks Andre - Altera_Forum
No,i suggest you try to understand what verilog is really created for.If you want to create a verilog file for synthesis,do not use initial or such sentence.If you want to write a testbench,refer to the books,and you'll see how you should implement this.
