14 years agoVerilog task driving a bidirectional bus
I'm using SystemVerilog, writing a test bench to test a device that has a bidirectional bus. I have been successful directly writing a sequence of statements that put the data on the bus and pulse the write line. But that is cumbersome to write a lot of data. So I want to use the Verilog task capability. I can't seem to get it to drive the bus at all.
Here is the code simplified:
module test();
wire data; // the bidirectional data bus
reg wr; // the write enable line
logic send_data; // the register for writing data
my_device u1(
.data,
.wr
assign data = send_data;
initial begin
write_gpbus(8'h08);
end
task write_gpbus;
input reg data_to_send;
begin
send_data = data_to_send;
# 50ns wr = 1'b1;
# 50ns wr = 1'b0;
end
endmodule
When I run this I can see send_data getting the correct value of the parameter passed into the task. But data (the actual bus) is always unknown, never gets a value. If I were to just write directly to the send_data not using the task (as in the code below), then data does get the value. What am I doing wrong here?
initial begin
send_data = 8'h08;
end
1 Reply
Never mind! I had some unfinished faulty logic in my_device that was driving the data bus to the unknown state. After turning that off the task correctly drives the bidirectional bus (at least in the output direction).
