16 years agoverilog module output to NULL
I created a complex module. Not all output using all the time. How can I redirect the unused outputs too "null". sample: uart_rx rx1 (.reset(uart_rst), .rxclk(baud_clk), .rx_rea...
16 years agoStrictly speaking, if you don't want to use a port on a module, just don't connect it to anything. The synthesis tool is smart enough to remove any logic driving the ports.
Examples:uart_rx rx1 (
.reset(uart_rst),
.rxclk (baud_clk ),
.rx_read (rs ),
.rx_data (data ),
.rx_in (rx ),
.rx_empty ( ),
.rx_busy ( )
or uart_rx rx1 (
.reset(uart_rst),
.rxclk (baud_clk ),
.rx_read (rs ),
.rx_data (data ),
.rx_in (rx )
); Alternatively, you can use a macro to get rid of it: uart_rx rx1 (
.reset(uart_rst),
.rxclk (baud_clk ),
.rx_read (rs ),
.rx_data (data ),
.rx_in (rx )
`ifndef USE_WORTHLESS_PORTS
.rx_empty ( ),
.rx_busy ( )
`endif
And you can use synthesis directives if you don't want it in there for synthesis but do for simulation: uart_rx rx1 (
.reset(uart_rst),
.rxclk (baud_clk ),
.rx_read (rs ),
.rx_data (data ),
.rx_in (rx )
// synthesis translate_off
.rx_empty ( ),
.rx_busy ( )
// synthesis translate_on
); Jake
