11 years agoVERILOG LCELL Simulation
I have implemented a ring oscillator using LCELLs. I am able to simulate it using ModelSim-Altera with the following VHDL statement:
ring: for k in 0 to NUM_LUTS-1 generate begin inst_lcell : LCELL port map(a_in => lut_ring(k), a_out => lut_ring(k+1) ); end generate; lut_ring(0) <= lut_ring(NUM_LUTS-1) xor not(constq) after 1.702ns; Simulation shows an oscillating output. I have written the same code in Verilog. genvar i; generate for (i=0; i<NUM_LUTS-1; i++) begin : lut_ring // ALTERA BUG: LCELL must be lowercase for simulator lcell lcell_inst ( .in ( lut_wire[i] ), .out ( lut_wire[i+1] ) ); assign lut_wire[0] = lut_wire[NUM_LUTS-1] ^ ~constant; How do you simulate it? If I put a# 1.702 after the ASSIGN it doesn't work! If you put# 1.702 before the ASSIGN you get an error. Thanks.1 Reply
After a few hours of searching, reading and experimenting I finally found out how to simulate it. It's not the way it should be but it works! Verilog is more troublesome to simulate than VHDL. Oh well, the way it is.
Thanks anyway.
