17 years ago
Verilog Generic Input ports
Hi All,
I have an input port to a module which is 5 bits say Inp_A[4:0]. Now the number of such inputs depends on a generic parameter say Gen_Nm.
How can i declare such an input ports in my module.
I have tried
Input [4:0][Gen_Num-1 : 0] Inp_A; &
Input [Gen_Num-1 : 0][4:0] Inp_A; &
Input [Gen_Num-1 : 0] Inp_A[4:0]; &
Input [4:0] Inp_A[Gen_Num-1 : 0];
All these seems to be giving compile error.
Please help me, how to go about this
regards,
freak
    Hi Schmitt,
    The example given
    input [4:0] Inp_A [Gen_Num-1:0]; // should give Gen_Num x 5 bit input
    is not working.
    The compiler is throwing error saying that, this is a System Verilog construct.
    Verilog does not support Memory type port declaration.
    What is your thoughts on this .
    regards,
    freak
    your last example is the correct one.
    check that parameter is declared within the same file like :
    module dummy_mod( Inp_A );
    parameter Gen_Num = 3
    endmodule
    but i have seen that quartus sometimes seems to have problems with parameters
    if i use them then i do the following
    parameter ReloadValue = 47;
    wire [5:0] wReloadValue;
    assign wReloadValue = ReloadValue;
    somewhere this can be used as
    rTestReg <= rMyValue + wReloadValue ;
    assigning a wire with the parameter works, using the parameter directly doesn't
    no idea why
