17 years agoVerilog: Concept on Blocking assignment and always
i read an article about blocking assignment. module fbosc1 (y1, y2, clk, rst); output y1, y2; input clk, rst; reg y1, y2; always @(posedge clk or posedge rst) if (rst) y1 = 0; // r...
17 years ago --- Quote Start --- Question: 1. How is the flow for above case in terms of always block and blocking assignment? 2. if reset = 1, y1=0 and y2=1, isn't it? i don understand the explaination above. So, Try to explain in details. --- Quote End --- Dear jasonkee111, when you are talking about the simulation semantics of verilog, your remark is correct. For synthesis however the signal assignments within an
always @(posedge clk or posedge rst)construct will be synthesized as D type flip-flops. The if (rst) ... ; construct within the always will be synthesized as sets or presets of the flipflops. The rest of the code will determine the combinatorial logic at the input of the flip-flops. As a result of this. The two flip flops will be reset in the beginning at the correct level: y1 = 0 and y2 = 1. After that the two flip-flops will toggle at each positive edge of the clock signal. When writing this code with blocking or non-blocking statements the two descriptions will have the same behavior. If you want to have your simulation correspond to the synthesized circuit you could use the non-blocking construct in this case. Within an always construct blocking and non-blocking constructs could of course have different semantics in the determination of what circuit is being synthesized. Hope this helps...
