17 years agoVerilog Coding Help Needed!
Hi ,
I have Altera Cyclone III board and Quartus II 8.1. I also have Bitec HSMC DVI daughter board. My SOPC Design is : DVI_IN => new component => Frame Buffer => DVI_OUT My goal is to take my DVI display input , XOR it with some random value and output DVI output. I have the following code which is giving me a black screen. I actually have a more complex version of this code where I try to XOR my input data but seems like I can't pass through data between "data in" and "data out" Please keep in mind that I did pass through data without using registers but since I also want to do XORing, I try to use the following model. module new_component ( clk, data_in, data_out, eop_in, eop_out, ready_in, ready_out, reset, sop_in, sop_out, valid_in, valid_out ); input clk; input [23:0] data_in; output [23:0] data_out; input eop_in; output eop_out; input ready_in; output ready_out; input reset; input sop_in; output sop_out; input valid_in; output valid_out; wire clk; wire [23:0] data_in; reg [23:0] data_out; wire eop_in; reg eop_out; wire ready_in; reg ready_out; wire reset; wire sop_in; reg sop_out; wire valid_in; reg valid_out; always @(posedge clk ) begin ready_out <= ready_in; valid_out <= valid_in; sop_out <= sop_in; eop_out <= eop_in; data_out <= data_in; end endmodule Please someone help me, this is urgent. Thank you so much in advance, TylerNo RepliesBe the first to reply
