jaykrishna1's avatar
jaykrishna1
Icon for New Member rankNew Member
20 hours ago
Vcm for the clock input pins of agilex5 E-series FPGA A5ED065BB32AE5SR0
We are working with the following differential clock input pins:
- CLK_[T,B]_2[A,B]_[0:1] (P/N)
- CLK_[T,B]_3[A,B]_[0:1] (P/N)
Could you please confirm the allowed common-mode voltage range for these differential clock inputs?
  • FvM's avatar
    FvM
    Hi Jay,
    you can refer to datasheet for suitable Vicm range. Most Devkits are biasing AC coupled TDS input to Vccio/2 with 4 resistors 1k - 10k.
    Regards Frank
  • Hi,
    Do we need to provide external biasing for these clock inputs? If yes, what should be the required input common-mode voltage?
    Jay
  • Farabi's avatar
    Farabi
    1. Each pin voltage does not exceed VCCIO voltage. Differential clock Vcm within VCCIO. Operational is guaranteed.
    2. If you implement LVDS , the Vcm = 1.2V which exceeds VCCIO. So it will need AC coupling when driving HSIO clock inputs from standard LVDS sources. This will allow Agilex 5 HSIO input biasing to establish a compliant Vcm.
    regards,
    Farabi
