16 years agoVCCIO and EPCS Issue
Hi, All We are using EPCS and CycloneIII device. As EPCS can only support 3.3V, the IO pin connect seems must Power by 3.3V, which means VCCIO of Bank1 in FPGA must tie to 3.3V power. Then h...
16 years ago --- Quote Start --- The MSEL pins are completely independent. They are always used at 2.5V, and you can use any voltage you want for bank 6. --- Quote End --- Great! Thanks
