16 years agoVCCIO and EPCS Issue
Hi, All We are using EPCS and CycloneIII device. As EPCS can only support 3.3V, the IO pin connect seems must Power by 3.3V, which means VCCIO of Bank1 in FPGA must tie to 3.3V power. Then h...
16 years agoPage 11 of this PDF says :
--- Quote Start --- Hardwire the MSEL pins to VCCA or GND without any pull-up or pull-down resistors to avoid any problems detecting an incorrect configuration scheme. Do not drive the MSEL pins with a microprocessor or another device. --- Quote End --- But if that means that this bank needs to be 2.5V too, i don't think so that MSEL interfears with Vio of a bank, but look into the pdf of your device.
