13 years agoUsing sdram_control_4Port module in VHDL
All,
I am new to VHDL. I am trying to use the sdram_control_4Port form the terasic to read and write to SDRAM. The end goal is to use the TRDB_D5M camera to capture and image then modify the data in the SDRAM and display the image on the screen. The hardware platform is DE2-70 board Bellow is my code. Any help is appreciated. LIBRARY ieee; USE ieee.std_logic_1164.all; ENTITY final_project IS PORT ( --////////////////// Clock Input //////////////////// iCLK_28 : IN STD_LOGIC; -- 28.63636 MHz iCLK_50 : IN STD_LOGIC; -- 50 MHz iCLK_50_2 : IN STD_LOGIC; -- 50 MHz iCLK_50_3 : IN STD_LOGIC; -- 50 MHz iCLK_50_4 : IN STD_LOGIC; -- 50 MHz iEXT_CLOCK : IN STD_LOGIC; -- External Clock --////////////////// Push Button //////////////////// iKEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0); -- Pushbutton[3:0] --////////////////// DPDT Switch //////////////////// iSW : IN STD_LOGIC_VECTOR(17 DOWNTO 0); -- Toggle Switch[17:0] --///////////////////// SDRAM Interface //////////////// DRAM_DQ : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0); -- SDRAM Data bus 32 Bits oDRAM0_A : OUT STD_LOGIC_VECTOR (12 DOWNTO 0); -- SDRAM0 Address bus 13 Bits oDRAM1_A : OUT STD_LOGIC_VECTOR (12 DOWNTO 0); -- SDRAM1 Address bus 13 Bits oDRAM0_LDQM0: OUT STD_LOGIC; -- SDRAM0 Low-byte Data Mask oDRAM1_LDQM0: OUT STD_LOGIC; -- SDRAM1 Low-byte Data Mask oDRAM0_UDQM1: OUT STD_LOGIC; -- SDRAM0 High-byte Data Mask oDRAM1_UDQM1: OUT STD_LOGIC; -- SDRAM1 High-byte Data Mask oDRAM0_WE_N : OUT STD_LOGIC; -- SDRAM0 Write Enable oDRAM1_WE_N : OUT STD_LOGIC; -- SDRAM1 Write Enable oDRAM0_CAS_N: OUT STD_LOGIC; -- SDRAM0 Column Address Strobe oDRAM1_CAS_N: OUT STD_LOGIC; -- SDRAM1 Column Address Strobe oDRAM0_RAS_N: OUT STD_LOGIC; -- SDRAM0 Row Address Strobe oDRAM1_RAS_N: OUT STD_LOGIC; -- SDRAM1 Row Address Strobe oDRAM0_CS_N : OUT STD_LOGIC; -- SDRAM0 Chip Select oDRAM1_CS_N : OUT STD_LOGIC; -- SDRAM1 Chip Select oDRAM0_BA : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); -- SDRAM0 Bank Address oDRAM1_BA : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); -- SDRAM1 Bank Address oDRAM0_CLK : OUT STD_LOGIC; -- SDRAM0 Clock oDRAM1_CLK : OUT STD_LOGIC; -- SDRAM1 Clock oDRAM0_CKE : OUT STD_LOGIC; -- SDRAM0 Clock Enable oDRAM1_CKE : OUT STD_LOGIC; -- SDRAM1 Clock Enable --/////////////////////// LED //////////////////////// oLEDG : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); -- LED Green[8:0] oLEDR : OUT STD_LOGIC_VECTOR (15 DOWNTO 0) -- LED Red[15:0] ); END final_project; ARCHITECTURE circuit OF final_project IS SIGNAL sdram_ctrl_clk: STD_LOGIC ; SIGNAL WR1_FULL,WR2_FULL,RD1_EMPTY,RD2_EMPTY: STD_LOGIC ; SIGNAL WR1_USE,WR2_USE,RD1_USE,RD2_USE: STD_LOGIC_VECTOR (8 DOWNTO 0) ; SIGNAL RD2 : STD_LOGIC_VECTOR (15 DOWNTO 0); SIGNAL DRAM0_CS_N,DRAM1_CS_N,DRAM0_DQM,DRAM1_DQM : STD_LOGIC_VECTOR (1 DOWNTO 0) := b"00" ; SIGNAL DRAM0_A,DRAM1_A : STD_LOGIC_VECTOR(11 DOWNTO 0); SIGNAL RD2_temp : STD_LOGIC_VECTOR (15 DOWNTO 0); COMPONENT sdram_pll IS PORT ( inclk0 : IN STD_LOGIC; c0 : OUT STD_LOGIC; c1 : OUT STD_LOGIC; c2 : OUT STD_LOGIC ); END COMPONENT; COMPONENT Sdram_Control_4Port IS PORT ( --HOST Side REF_CLK : IN STD_LOGIC; --System Clock RESET_N : IN STD_LOGIC; --System Reset CLK : IN STD_LOGIC; -- -- FIFO Write Side 1 WR1_DATA : IN STD_LOGIC_VECTOR (15 DOWNTO 0); --Data input WR1 : IN STD_LOGIC; --Write Request WR1_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write start address WR1_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write max address WR1_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Write length WR1_LOAD : IN STD_LOGIC; --Write register load & fifo clear WR1_CLK : IN STD_LOGIC; --Write fifo clock WR1_FULL : OUT STD_LOGIC; --Write fifo full WR1_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Write fifo usedw -- FIFO Write Side 2 WR2_DATA : IN STD_LOGIC_VECTOR (15 DOWNTO 0); --Data input WR2 : IN STD_LOGIC; --Write Request WR2_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write start address WR2_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Write max address WR2_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Write length WR2_LOAD : IN STD_LOGIC; --Write register load & fifo clear WR2_CLK : IN STD_LOGIC; --Write fifo clock WR2_FULL : OUT STD_LOGIC; --Write fifo clock WR2_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Write fifo usedw -- FIFO Read Side 1 RD1_DATA : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); --Data output RD1 : IN STD_LOGIC; --Read Request RD1_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read start address RD1_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read max address RD1_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Read length RD1_LOAD : IN STD_LOGIC; --Read register load & fifo clear RD1_CLK : IN STD_LOGIC; --Read fifo clock RD1_EMPTY : OUT STD_LOGIC; --Read fifo empty RD1_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Read fifo usedw -- FIFO Read Side 2 RD2_DATA : OUT STD_LOGIC_VECTOR (15 DOWNTO 0); --Data output RD2 : IN STD_LOGIC; --Read Request RD2_ADDR : IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read start address RD2_MAX_ADDR: IN STD_LOGIC_VECTOR (22 DOWNTO 0); --Read max address RD2_LENGTH : IN STD_LOGIC_VECTOR (8 DOWNTO 0); --Read max address RD2_LOAD : IN STD_LOGIC; --Read register load & fifo clear RD2_CLK : IN STD_LOGIC; --Read fifo clock RD2_EMPTY : OUT STD_LOGIC; --Read fifo empty RD2_USE : OUT STD_LOGIC_VECTOR (8 DOWNTO 0); --Read fifo usedw -- SDRAM Side SA : OUT STD_LOGIC_VECTOR (11 DOWNTO 0); --SDRAM address output BA : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); --SDRAM bank address CS_N : OUT STD_LOGIC_VECTOR (1 DOWNTO 0); --SDRAM Chip Selects CKE : OUT STD_LOGIC; --SDRAM clock enable RAS_N : OUT STD_LOGIC; --SDRAM Row address Strobe CAS_N : OUT STD_LOGIC; --SDRAM Column address Strobe WE_N : OUT STD_LOGIC; --SDRAM write enable DQ : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0);--SDRAM data bus DQM : OUT STD_LOGIC_VECTOR (1 DOWNTO 0) --SDRAM data mask lines ); END COMPONENT; BEGIN u1 : sdram_pll PORT MAP (iCLK_50,sdram_ctrl_clk,oDRAM0_CLK,oDRAM1_CLK); u2 : Sdram_Control_4Port PORT MAP (iCLK_50,'1',sdram_ctrl_clk,b"0001000100010001",'1',b"00000000000000000000000",b"00101000000000000000000",b"100000000",'1',iCLK_28,WR1_FULL,WR1_USE, b"0000000000000000",'-',b"00000000000000000000000",b"00000000000000000000000",b"000000000",'0','Z',WR2_FULL,WR2_USE, oLEDR,'1',b"00000000000000000000000",b"00101000000000000000000",b"100000000",'1',iCLK_28,RD1_EMPTY,RD1_USE, RD2_temp,'-',b"00000000000000000000000",b"00101000000000000000000",b"100000000",'0','Z',RD2_EMPTY,RD2_USE, DRAM0_A,oDRAM0_BA,DRAM0_CS_N,oDRAM0_CKE,oDRAM0_RAS_N,oDRAM0_CAS_N,oDRAM0_WE_N,DRAM_DQ,DRAM0_DQM); oDRAM0_A <= "0"&DRAM0_A; oDRAM0_CS_N <= '0' WHEN (DRAM0_CS_N = "00") ELSE '1'; oDRAM0_LDQM0<=DRAM0_DQM(0); oDRAM0_UDQM1<=DRAM0_DQM(1); oLEDG(0)<=sdram_ctrl_clk; END ARCHITECTURE;No RepliesBe the first to reply
