8 years agoUsing Cypress FX3 as device for Passive Serial
Hey, So I'm working on a setup with the Cyclone 3 (specifically EP3C5E144C8N), which uses a Cypress FX3 board as the passive serial initialisation device. Unfortunately I cant seem to get the d...
8 years agonSTATUS going low before configuration completes indicates the FPGA has detected an error.
I'm concerned about the relative timing between the clock and data. If you're configuring from such a remote source - by the looks of the FX3 solution it's going to be quite a lot further from the FPGA than ideal - then 25MHz sounds a little punchy to me, regardless of the 133MHz max speed supported by Cyclone III. What does the relative timing between DCLK and DATA0 look like at the FPGA? Cheers, Alex
