11 years agoUsing Altera GPIO Lite Ip core as bidirectional DDR
Hi, I have a signal whose data rate is 480Mbps. it is a DDR signal. I would like to know whether by using GPIO Ip i can acheive this ?. What would be the IO standard for the ddr output of GPIO...
11 years agoYes, that sounds reasonable.
Yes, the GPIO IP will allow you to generate a DDR signal you can drive to a pad. The same IP supports bidirectional ports as well. You can use 1.2V LVCMOS as the I/O standard, although that's not very common. As the tools will tell you a 1.2V I/O standard may have lower performance than I/O standards at higher voltages. Finally, as I frequently state on this forum - put a simple design together, constrain it and run it through Quartus. Quartus will answer all the questions you've asked. Cheers, Alex
