16 years agoUSB cyclone 3 starter board
Hi all, I'm using Altera cyclone 3 starter board... can i use USB port for pc application (What should I have to add in SOPC and in the application)?
16 years agoYou can communicate through the JTAG interface using the JTAG UART, but you need the Altera JTAG driver stack installed on the PC to use the respective DLLs. There's also a second link, that enables the access method used in previous Terasic Dev Kits. It can work on the generic FTDI driver without the Altera stack.
It's a kind of serial Altera Forum topic. http://www.alteraforum.com/forum/showthread.php?t=18600 http://www.alteraforum.com/forum/showthread.php?t=6682 http://www.alteraforum.com/forum/showthread.php?t=6604
