16 years agoUSB cyclone 3 starter board
Hi all, I'm using Altera cyclone 3 starter board... can i use USB port for pc application (What should I have to add in SOPC and in the application)?
16 years agoNo you cannot.
The USB connector is only for programming the FPGA. The signal flow is: from the programmer software through the cable and the USB connector to the CPLD on the board which contains the equivelent of the USB-Blaster POD code - the output of which is a JTAG connection to your FPGA.
