JackMyers
3 years agoUSB-Blaster will not program in Quartus Prime Programmer Lite
I can connect my USB-Blaster and select it in the hardware setup however when I try to program my device (10M02SCU169) it identifies the JTAG chain but fails the programming operation at 4% progress....
WZ2
3 years agoHi there,
Any update~
- JackMyers3 years ago
Thank you for your reply and apologies for the delayed response.
I did not find the root cause of the issue however I did find a workaround. I reverted to an older software version (19.1) and the USB-Blaster functioned correctly. I can now program without an issue and everything functions correctly.
Jack
