JackMyers
3 years agoUSB-Blaster will not program in Quartus Prime Programmer Lite
I can connect my USB-Blaster and select it in the hardware setup however when I try to program my device (10M02SCU169) it identifies the JTAG chain but fails the programming operation at 4% progress....
JackMyers
3 years agoThank you for your response,
Yes, I have moved the USB Blaster and target board over to another PC and it programs correctly.
I am using Quartus Prime Version 22.1std1 build 917 02/14/2023 SC Lite Edition.
My version of Windows is: Windows 10 Version 21H2 Build 19044.3086
The drivers installed for the USB-Blaster are the same on each machine and located in the driver's folder that came with the Quartus install, e.g: C:\intelFPGA_lite\22.1std\quartus\drivers\usb-blaster
I understand this must be drivers for the USB Blaster causing an issue but I have tried multiple driver versions and all of them produced the same issue.
Jack
