JackMyers
3 years agoUSB-Blaster will not program in Quartus Prime Programmer Lite
I can connect my USB-Blaster and select it in the hardware setup however when I try to program my device (10M02SCU169) it identifies the JTAG chain but fails the programming operation at 4% progress....
_AK6DN_
3 years agoYou say: "The same setup I am using works on a different Windows 10 PC"
Does this mean you move the USB Blaster and target board over to another PC and it programs correctly?
If so, it is then obvious that the Quartus install and/or USB Blaster drivers on the original machine are suspect.
You need to provide a lot more information about your setup.
Exactly what version of Quartus on each machine.
What version of Windows 10 on each machine.
What USB driver is installed on each machine.
