USB Blaster not available
Hi Terry,
that looks good. Unless you don't install manually, jtagserver of last installed Quartus version will be used. However if you have Quartus Std and Pro versions on your computer, you'll use Quartus Pro jtagserver because Quartus Std. server won't recognize some advanced FPGA.
Frank
Hi Frank,
I just tried my Windows 11 laptop which only has 24.1 installed and I get the same result. The programmer won't recognize the USB blaster when the Rabbit programming cable is connected. It looks like it must be unique to my setup
Thanks for the help
- Farabi_Altera8 months ago
I am sorry, I tried to understand your setup here. What is Rabbit microcontroller do and what its relation with USB Blaster II ?
Basically, USB Blaster II only use for Altera device.
regards,
Farabi
- 3LionsCT8 months ago
Hi Farabi,
the rabbit is a self contained 8 bit microcontroller with a Ethernet jack. I use it along with a Max 10 device in a system. The rabbit handles all of the ethernet communication and the the Max 10 all the real time control.
The rabbit runs a C program which is downloaded and debugged over usb using a FTDI device. This means in development mode I need two com ports. One for the usb blaster and one for the rabbit. The usb blaster works fine until I connect the rabbit. Once I connect the rabbit, the usb blaster option disappears from the Quartus programmer.regards
I am sorry, we can't help much on that. The USB Blaster II should have access to 1 COM port and rabbit should have accesss another COM port.
You need to check in your device manager etc. Basically USB Blaster II is working but have contention issue with Rabbit connector.
regards,
Farabi
