USB Blaster driver conflict with other FTDI kit
Having the same issue with Windows 10 Enterprise 64 bit. As long as I have a FTDI based USB to serial converter plugged in and opened in a terminal, Quartus doesn't list the USB Blaster as a selectable hardware. If I plug out the USB to serial converter, the USB Blaster works fine.
- Drivers for both devices installed fine without any exclamation mark or error message
- USB to serial chip is FT2232C/D/H Dual UART/FIFO IC; Driver is ftser2k.sys, V2.12.28.0
- Terasic blaster has FT245BL chip; Driver is usbblstr.sys, V2.12.00.2 as contained in Quartus 16.1 and Quartus 18.1
I see this thread was opened 11 years ago, any chance that there will ever be a solution?
I now have the same problem. I have been using Quartus 14 without problem for quite some time. This morning I upgraded to 20.x and now I have the same problem.
I have to shut Putty down in order to download to my FPGA. What a pain.
Looks like I'm going to need a second PC to run Putty..
- avib5 years ago
I'm also having the same problem of not being able to use the USB to serial together with the USB Blaster.
There is a way to workaround Programming by disconnecting the USB to serial and re-attaching it after the programming was completed, but there is no way to use SignalTap since I need the serial port connected during the debugging...
I've tried many Quartus driver versions, and the latest USB to serial driver, but it still doesn't work.
