15 years agoUrgent: Different timing analysis result for DMA
Hello, I did a timing analysis for DMA to transfer 2MB of data. The first time i executed it, using DMA, the system improved by 88.75%. When I ran it for 2nd time, the performance became 48.5% only. why the performance will decrease from 88.75% to 48.5%? I did not change the code or the core.
Yeah, it is correct now. I did a mistake by adding some function in DMA part. Thanks!
Do you run it twice in a row from the same software, do you re-upload a new software between the two tests, or are you reconfiguring the FPGA and upload the software between the two tests?
You should put some Signaltap probes on the DMA's master to see if anything different is happening during the tests.
