9 years agoup/down counter
Hello, can i get help for this program i am new to altera. i need help making a program that has an up and down counter from 15-0 using pushbuttons and 2 seven 7-segments display if its a...
9 years agoHello Malvin,
I wrote some code for the DE0_CV that generates a counter 0-255 based on 2 push buttons Key(0) and Key(1) It sends the output to 2 7 seg display counters on a DE0-CV. The quartus archive file is also included.library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
-- interface with the pins of the fpga (imported file .csv for pin planner)
entity ent_main is
port(
-- clock on DE board:
clock2_50: in std_logic;
-- reset button:
reset_n : in std_logic;
-- push buttons:
key: in std_logic_vector(3 downto 0);
-- hex 7 seg displays:
hex0: out std_logic_vector(6 downto 0);
hex1: out std_logic_vector(6 downto 0)
end ent_main;
architecture arch_main of ent_main is
signal counter : integer range 0 to 255;
signal okey : std_logic_vector(3 downto 0);
begin
-- counter logic:
process(clock2_50)
begin
if (clock2_50'event and clock2_50='1') then
if (reset_n='0') then -- reset button pressed ?
counter <= 0; -- reset counter
okey <= "0000"; -- helper value to rememer previous state of buttons
else
if (key(0)='0' and okey(0)='1') then -- this cycle button pressed and previous cycle not pressed
counter<=counter+1; -- increment counter
elsif (key(1)='0' and okey(1)='1') then -- this cycle button pressed and previous cycle not pressed
counter<=counter-1; -- increment counter
else
counter<=counter; -- keep counter value
end if;
okey <= key; -- remember previous value of counter
end if;
end if;
end process;
-- display hex value on 7-seg
-- display bits 0 to 3 on first part of 7seg
led0: entity work.ent_led7seg(arch_led7seg)
port map(data=>std_logic_vector(to_unsigned(counter,8))(3 downto 0),leds=>hex0);
-- display bits 7 to 4 on first part of 7seg
led1: entity work.ent_led7seg(arch_led7seg)
port map(data=>std_logic_vector(to_unsigned(counter,8))(7 downto 4),leds=>hex1);
end arch_main; and
library ieee;
entity ent_led7seg is
port(data: in std_logic_vector(3 downto 0);
leds : out std_logic_vector(6 downto 0)
end ent_led7seg;
architecture arch_led7seg of ent_led7seg is
begin
with data select
leds<="1000000" when "0000",
"1111001" when "0001",
"0100100" when "0010",
"0110000" when "0011",
"0011001" when "0100",
"0010010" when "0101",
"0000010" when "0110",
"1111000" when "0111",
"0000000" when "1000",
"0010000" when "1001",
"0001000" when "1010",
"0000011" when "1011",
"1000110" when "1100",
"0100001" when "1101",
"0000110" when "1110",
"0001110" when "1111",
"0001000" when others;
end arch_led7seg;
Best Regards, Johi.
