16 years agoUnknown file created by modelsim
After running the simulation in modelsim, i realise that there are a lot of files created name like wlf......(format:file) which consume a lot of space. It seems like a waveform file based on the name of the file starts with wlf. When i open to view it using notepad, it is not understandable.
Is this file important? What is the file used for? Can i delete it? thanks1 Reply
No, it's not quite important~
It really is waveform file, not a source file or some important settings, you can delete it if you don't need to keep the simulation result.
