16 years agoUniversity SD CARD IP did not read
I added the altera_up_avalon_sd_card_interface into nios system.The SD card can be detected, and the READ_BLOCK command can be executed but no data be written in SD_CARD_BUFFER.Following is the code: --------------------------------------------------------- device_reference = alt_up_sd_card_open_dev(SD_CARD_NAME); if(device_reference == NULL) printf("SD Card was not found.\n"); if (device_reference != NULL) { fprintf(fp,"\n write_read from %x\n",SD_CARD_BASE); for(i=0;i<512;i++)(*((volatile unsigned char *)SD_CARD_BUFFER(SD_CARD_BASE, i)))=i & 0xff; for(i=0;i<512;i++)bb[i]=(*((volatile unsigned char *)SD_CARD_BUFFER(SD_CARD_BASE, i))); for(i=0;i<64;i++) fprintf(fp,"%2x,%2x,%2x,%2x,%2x,%2x,%2x,%2x\n",bb[8*i],bb[8*i+1],bb[8*i+2],bb[8*i+3],bb[8*i+4],bb[8*i+5],bb[8*i+6],bb[8*i+7]); fprintf(fp,"write_read ok\n\n"); if (Read_Sector_Data(0, 0)) { for(i=0;i<64;i++) fprintf(fp,"%2x,%2x,%2x,%2x,%2x,%2x,%2x,%2x\n",bb[8*i],bb[8*i+1],bb[8*i+2],bb[8*i+3],bb[8*i+4],bb[8*i+5],bb[8*i+6],bb[8*i+7]); fprintf(fp,"read_sector ok\n\n"); } } ------------------------------------------------------------- Where Read_Sector_Data() coming from "altera_up_sd_card_avalon_interface.c" as following: --------------------------------------------------------------- bool Read_Sector_Data(int sector_index, int partition_offset) // This function reads a sector at the specified address on the SD Card. { bool result = false; if (alt_up_sd_card_is_Present()) { short int reg_state = 0xff; /* Write data to the SD card if the current buffer is out of date. */ if (current_sector_modified) { if (Write_Sector_Data(current_sector_index, 0) == false) { return false; } } /* Multiply sector offset by sector size to get the address. Sector size is 512. Also, * the SD card reads data in 512 byte chunks, so the address must be a multiple of 512. */ *command_argument_register = (sector_index + partition_offset)*512; *command_register = CMD_READ_BLOCK; do { reg_state = *aux_status_register; } while ((reg_state & 0x04)!=0); // Make sure the request did not time out. if ((reg_state & 0x10) == 0) { result = true; current_sector_modified = false; current_sector_index = sector_index+partition_offset; } } return result; } -------------------------------------------------------------------------- The strange thing is that the data in SD_CARD_BUFFER after READ_BLOCK were same as the data in SD_CARD_BUFFER before READ_BLOCK. Looking for your help. Thanks in advance.No RepliesBe the first to reply
