16 years agoUnassigned pins of top level entity
Sometimes in simulation, I add some pins to the top level entity, but then I will not use them. What happen with the unassigned pins of the top level entity? Are they connected to some output pin of the FPGA?. Thank you1 Reply
--- Quote Start --- Are they connected to some output pin of the FPGA?. --- Quote End --- Yes, if you define output ports. The pin list can tell.
