10 years agoUnable to write on SDRAM on DE0- Nano Cyclone IV E - waitrequest
I have a problem on a project on De0-Nano eval board (Cyclone IV E). I have no idea where look or what I'm wrong. I design a system made by: a I2S receiver connected to a fifo and the fifo to a Master Avalon-MM (Qsys System). The strange behaviour is: I cannot write on SDRAM when I use the signals generated by I2S signals instead works correctly with the below piece of VHDL process(clk, rstN)
variable cnt : integer range 0 to 255 := 0;
begin
if (rstN = '0') then
count <= (others => '0');
ready <= '0';
elsif rising_edge(clk) then
if count = 0 then
ready <= '1';
left_channel_in <= x"1234" & std_logic_vector ( to_unsigned( cnt, 16) );
right_channel_in <= x"ABCD" & std_logic_vector ( to_unsigned( cnt, 16) );
cnt := cnt +1;
else
ready <= '0';
end if;
count <= count + 1;
end if;
end process;
Below, the signals on avalon bus, in the case of usage of above vhdl http://www.alteraforum.com/forum/attachment.php?attachmentid=11997&stc=1 If I connect the I2S Reciever to rest of system, it doesn't work, see the image (the waitrequest after the first write never goes low) http://www.alteraforum.com/forum/attachment.php?attachmentid=11998&stc=1 I don't understand why : in both tests the code which manages the SDRAM is the same and I write in both case to a fifo. Has Anyone an idea?3 Replies
those warnings are caused by two different configuration of the system (KO and OK): in one case (KO) I use "i2s_rx_data_valid" in the other "OK" the signal step. In any case I decided to clean this and bring the qsys system on top-level module: the funny thing is now seems to work (I'll post the whole system code) but I'm really afraid because this means (maybe, I'm investigating) a change in place&route makes the design not working. One interesting result: the TimeQuest Analyzer report only 1 "Worst-Case Slack" on clock signal to SDRAM, but I'm not able to evaluate this report and if I have to do anything. https://www.alteraforum.com/forum/attachment.php?attachmentid=12003 - Altera_Forum
The simulation plots you attached are so tiny it's impossible to read them. Good idea to diff the compilation output, I wish I had thought of doing that before, Quartus generates so much output. I also diffed the files and I see two other differences besides the timing issues: ko.txt: Warning (10036): Verilog HDL or VHDL warning at de0_nano.vhd(378): object "step" assigned a value but never read ok.txt: Warning (10036): Verilog HDL or VHDL warning at de0_nano.vhd(320): object "i2s_rx_data_valid" assigned a value but never read That warning about i2s_rx_data_valid never being assigned a value sounds fishy to me. - Altera_Forum
Attached the compilation reports generated by Quartus on both scenarios.
I made a diff and see (last part of files) some differences between Timing constraint but I don't know if these are the reason of issue.
