17 years agounable to scan device chain. cann't scan jtag chain
Hi, I am using Nios II Embedded Evaluation Kit (Cyclone III - EP3C25F324C6NES). Though it is having direct programming capability through the Usb cable. I like to test the Program...
17 years ago --- Quote Start --- Yah I observed that the Load LED (Blue) does not glow when I connect the USB Byte Blaster in J4 slot . But when I connect through the USB cable then it is glowing .... So, what could be the answer now ??? Is that the fault with the USB Byte Blaster ??? -Srinath. --- Quote End --- Hi Srinath, I don't know your Evaluation board very well, but as I remember from other board it could be that there are additional IC's in the Jtag Chain, like a Flash or MAX device. Is there a chapter in your board documentation how to setup the JTAG chain?
