17 years agounable to scan device chain. cann't scan jtag chain
Hi, I am using Nios II Embedded Evaluation Kit (Cyclone III - EP3C25F324C6NES). Though it is having direct programming capability through the Usb cable. I like to test the Program...
17 years agoYah I observed that the Load LED (Blue) does not glow when I connect the USB Byte Blaster in J4 slot .
But when I connect through the USB cable then it is glowing .... So, what could be the answer now ??? Is that the fault with the USB Byte Blaster ??? -Srinath.
