12 years agoUdp\ip tse
I am working with EVM == " Nios II Embedded Evaluation Kit (NEEK), Cyclone® III " I want work under UDP/IP protocol without the need the NicheStack IPv4 and Microc\OS . I want only send a f...
12 years agoAt first thanks for your cooperation !!!
I have a great labor to modify\adapt the ref design 3c120 to my EVM NEEK 3c20 , the hw is very different between the first and second EVM . All the project is wrote under verilog language and I do not know that syntax I know only vhdl language . So my inquiry is : 1_Do you have some project in vhdl code and no verilog is very very complicated to change that one ? . 2_about software folder where are located the c files ? I see 2 folder : one bsp\bsp_patches (what mean *.c.patch) another app folder .... I do not below that it is easy to send udp package from my EVM , I look up it is very complicated or no ?? Tx again , Shush
