Mohammed_Lami's avatar
Mohammed_Lami
4 years ago
"TrustZone_Cortex-A9AC6" example does not run normally
Hi, I am struggling in running the ready-examples of the ARM development studio IDE. I demonstrate the "TrustZone_Cortex-A9AC6" example here.
I am using the following resources:
1) "ARM Cyclone V SoC FPGA development kit".
2) Licensed copy of the ARM development studio IDE version 2021.1.
3) Windows 10 OS.
4) JTAG connection between the FPGA kit and the PC.
Please also refer to the snapshots in the attached pdf file for more details.
According to the description provided with this example "readme.html", the system should display some text on the "Target Console" like "Hello from Normal world" and so on. However, nothing was displayed on the Target Console although the system was running without a clear reason.
Any advice please to handle this issue? thanks a lot.
  • tehjingy_Altera's avatar
    tehjingy_Altera
    Hi Mohammed_Lami
    Did you use the debug configuration from the project it self?
    The FVP connection should work as it is a simulation.
    In my test run after connecting to the TrustZone_Cortex-A9_AC6-FVP in the Debug Control .
    I click the green play button under the Debug Control and I could see the print out in the Target Console.
    Below screenshots are the settings that are in debug configuration:
    Jingyang, Teh
    • Mohammed_Lami's avatar
      Mohammed_Lami
      Hi @JingyangTeh_Altera , many thanks for your response.
      Yes, I used the debug configuration from the project it self.
      The snapshots in your message didn't displayed (pls notice the snapshot below), this happened in Chrome and MS Edge browsers, can you please resend them (in word or pdf file) thanks a lot.
