"TrustZone_Cortex-A9AC6" example does not run normally
Hi Mohammed_Lami
Is it possible to run it without the debugger?
Could we try running it from a later address instead of starting from 0x8000006C?
Jingyang, Teh
Hi @JingyangTeh_Altera , thanks for your response
Actually, I tried to run it after shifting to 0x80000100, i.e. after 0x8000006C address, but the same problem happened at 0x80000106.
Please JingyangTeh, could you please confirm the following point:
1) The license that I am using was provided by the provider in the link below, and I think it is "silver license", is this type has some limitations that cause such problem?
https://www.mouser.co.uk/ProductDetail/Intel-Altera/ESW-DS-FIX?qs=GedFDFLaBXHRCPCuFYREfg%3D%3D#
2) The version of the Development Studio is Intel Edition 2021.1 as I mentioned previously, my license support only ARM compiler 6, is there some limitations come from the compiler?
3) I noticed that my license doesn't support the project that used ARMv8 instruction set architecture, it works with ARMv7 and below only, is there any issue with this point that can cause such problem?
4) The hardware that I use is ARM Cyclone V SoC Development Kit; if you recheck the error message that I sent in my last post "! Bus error on memory operation.", does this message mean that the problem in the bus between the memory and the A9 core not the memory itself? If so, which factors may affect that bus, is it possible to investigate this point please?
5) Regarding the ARM Cyclone V SoC Development Kit, it has different jumpers and dip switches that configure different things of the board, is the dip switch configuration that may affect such problem? For example, there are switches that determine the boot type.
6) When I power on the board, the LCD on it shows "No IP address is obtained" and "Hello Tim!" messages in two lines, isn't that mean Linux operation system has been loaded? If so, do you think this is normal?
Please if you have any other advice and suggestions will be appreciated.
Mohammed Lami
