"TrustZone_Cortex-A9AC6" example does not run normally
Hi @JingyangTeh_Altera , thanks for your suggestion
I removed the vector portion in the scatter file according to your suggestion, but I got the errors shown below when I tried to build the project, any suggestion please?
------------ Errors after building the project -----------------------------------------------
01:03:34 **** Build of configuration Debug for project startup_Cortex-A9_AC6 ****
make all
'Building file: ../sorts.c'
'Invoking: Arm C Compiler 6'
armclang --target=arm-arm-none-eabi -mcpu=cortex-a9 -mfpu=neon-fp16 -mfloat-abi=hard -marm -O0 -g -MD -MP -c -o "sorts.o" "../sorts.c"
'Finished building: ../sorts.c'
'Building file: ../startup.S'
'Invoking: Arm Assembler 6'
armclang.exe --target=arm-arm-none-eabi -mcpu=cortex-a9 -mfpu=neon-fp16 -mfloat-abi=hard -marm -g -c -o "startup.o" "../startup.S"
'Finished building: ../startup.S'
'Building target: ../startup_Cortex-A9_AC6.axf'
'Invoking: Arm Linker 6'
armlink.exe --entry=Vectors --scatter="../scatter.scat" --info=sizes -o "../startup_Cortex-A9_AC6.axf" ./sorts.o ./startup.o
Error: L6218E: Undefined symbol Image$$VECTORS$$Base (referred from startup.o).
Finished: 0 information, 0 warning and 1 error messages.
make: *** [makefile:31: ../startup_Cortex-A9_AC6.axf] Error 1
"make all" terminated with exit code 2. Build might be incomplete.
01:03:42 Build Failed. 2 errors, 0 warnings. (took 8s.186ms)
Also, I tried to run the project (with the vector) in steps to see where is the problem, I got the following error in the command view and Disassembly view, apparently, the system couldn't access the two addresses 0x80000068 and 0x8000006C. For your information and support please.
------------------- Error in the Disassembly view --------------------------
---------------- Error in the command view ------------------------
ERROR(CMD440-TAD10-NAL18):
! Stepping failed
! Failed to read 4 bytes from address S:0x8000006C
! Bus error on memory operation.
Target Message: Memory access caused precise abort.
Debug Precise Abort Registers : DFSR = 0x00001008, DFAR = 0x80000000
Debug Precise Abort Registers : DFSR = 0x00001008, DFAR = 0x80000068
Debug Precise Abort Registers : DFSR = 0x00001008, DFAR = 0x8000006C
