"TrustZone_Cortex-A9AC6" example does not run normally
Hi Mohammed_Lami
Could you please refer to this link on setting the scatter file.
To launch the project from the on-chip ram, you could follow the link below:
Else if you would like to launch the project from the SDRAM, you could follow the link below:
Jingyang, Teh
- Mohammed_Lami4 years ago
Many thanks for your support
I followed the two documents that you shared and unfortunately multiple errors were generated, I think these documents belong to the old version of Development Studio (DS5), which is not applicable to the new version that I am using right now (21.1). Are there similar documents for the newer versions of the DS please?
However, it seems that I got a successful startup for the board in the supervisory mode (SVC), the "startup_Cortex-A9_AC6" has been cleaned and rebuild, without modifying the scatter file, then I debug it in FVP mode, all messages in the commands view were normal and the data was loaded successfully, please check the messages below.
The project was imported from the archived projects, I only exchanged the "C-code" in the "sort.c" file with a simpler one, the code should return the value of a variable, but after the successful startup and clicking on the the "run" button, nothing was displayed in the Target console or in the App console.
Anyway, I attached the "startup_Cortex-A9_AC6" project here (with the modified "sort.c" file), could you please check it for me, thanks again for your support.
-------------- messages in the commands view --------------------------
Stopping running target Intel SoC FPGA - Cyclone V SoC (Dual Core) on connection
Connected to running target Intel SoC FPGA - Cyclone V SoC (Dual Core)
Execution stopped in SVC mode at S:0x8001E5C8
S:0x8001E5C8 MOV pc,lr
cd "C:\Users\Mohammed Lami\Development Studio Workspace"
Working directory "C:\Users\Mohammed Lami\Development Studio Workspace"
source /v "C:\Program Files\Arm\Development Studio 2021.1\sw\debugger\configdb\Scripts\altera_target_check.py"No SYSID registers could be found. Has a peripheral description file been supplied?
loadfile "C:\Users\Mohammed Lami\Development Studio Workspace\startup_Cortex-A9_AC6\startup_Cortex-A9_AC6.axf"
Loaded section VECTORS: S:0x80000000 ~ S:0x80000233 (size 0x234)
Loaded section RO_CODE: S:0x80000234 ~ S:0x800028D7 (size 0x26A4)
Loaded section RO_DATA: S:0x800028D8 ~ S:0x80002B0F (size 0x238)
Loaded section RW_DATA: S:0x80002B10 ~ S:0x80002B1B (size 0xC)
Entry point S:0x80000000
Semihosting server socket created at port 8000
Semihosting enabled automatically due to semihosting symbol detected in image 'startup_Cortex-A9_AC6.axf'
set debug-from *$ENTRYPOINT
start
Starting target with image C:\Users\Mohammed Lami\Development Studio Workspace\startup_Cortex-A9_AC6\startup_Cortex-A9_AC6.axf
Running from entry point
wait
Execution stopped in SVC mode at S:0x80000000
In startup.S
S:0x80000000 43,0 LDR PC, Reset_Addr
wait
continue-------------------------------------------------------------------------------------------------------------------------------
