15 years agotrouble while using two video source with DE2-70 board
hi! i am working for a project with DE2-70 board. i need two video input and one video output for my project want to switch video sources and also display two video frame by frame on the same scre...
15 years agoi think i have solved the problem for now.
From Assignments >> Settings >> Fitter Settings , you will also find an "Optimize hold timing" check. By changing its value to "All Paths" "Clock Hold:'iTD2_CLK27' " violation is removed and my design worked well. But, iTD2_CLK7 which is a dedicated external clock pin for the FPGA is still looks like not being used as global signal when i looked at the fitter resource report. i dont understand why but i think there is no problem for now :)
