Trouble interfacing FLASH pins to GPIO (retro game related)
Hey all,
Just got an Altera DE1 dev board using the Cyclone II, and I'm working on a simple test that is literally just connecting the FLASH chip to the GPIO_0 bus. I'm not performing any logic, but the FLASH does have code I wrote to it using the DE Control panel, and I've verified my code is correct. This is a test to send a small test ROM file from the DE1 to the GPIO ports which are connected to a Super Nintendo cartridge. I've done similar tests with Xilinx CPLD before (data lines ran direct to system, but address and control lines ran to CPLD), but this is my first foray into sending all pins through a FPGA. My problem is that the game will not boot! I've double and triple checked my wiring, and that's good. Each pin on the SNES just connects to one of the corresponding GPIO pins, which is routed to the FLASH pins through the FPGA. I've never run data lines through a PLD before, so I don't know if there is something special that they need in contrast to a regular address line? Or is there something glaringly obvious that I'm missing? I've attached my code in hopes someone can help me out. Also, I've already added FL_CE_N into my pin assignments as I noticed that it was missing originally.library ieee;use ieee.std_logic_1164.all;
entity mapper is
port(
FL_ADDR : out std_logic_vector(21 downto 0) ;
FL_DQ : out std_logic_vector(7 downto 0) ;
FL_CE_N : out std_logic;
FL_OE_N : out std_logic;
FL_RST_N : out std_logic;
FL_WE_N : out std_logic;
GPIO_0 : inout std_logic_vector(35 downto 0)
end mapper;
architecture arch of mapper is
begin
--CONTROL LINES
FL_CE_N <= '0';
FL_OE_N <= '0';
FL_RST_N <= '1';
FL_WE_N <= '1';
--DATA LINES
FL_DQ(7 downto 0) <= GPIO_0(21 downto 14);
-- ADDRESS LINES
FL_ADDR(17) <= GPIO_0(2);
FL_ADDR(16) <= GPIO_0(24);
FL_ADDR(15) <= GPIO_0(4);
FL_ADDR(14) <= GPIO_0(29);
FL_ADDR(13) <= GPIO_0(28);
FL_ADDR(12) <= GPIO_0(5);
FL_ADDR(11) <= GPIO_0(25);
FL_ADDR(10) <= GPIO_0(23);
FL_ADDR(9) <= GPIO_0(26);
FL_ADDR(8) <= GPIO_0(27);
FL_ADDR(7) <= GPIO_0(6);
FL_ADDR(6) <= GPIO_0(7);
FL_ADDR(5) <= GPIO_0(8);
FL_ADDR(4) <= GPIO_0(9);
FL_ADDR(3) <= GPIO_0(10);
FL_ADDR(2) <= GPIO_0(11);
FL_ADDR(1) <= GPIO_0(12);
FL_ADDR(0) <= GPIO_0(13);
end arch; Any ideas and help here would be greatly appreciated, thanks!17 Replies
The HIROM mode isn't the concern here. I know that works, but you're right in the future I could add an IF on A15. The system does have an A22 but it's not needed for this implementation. I don't think we need to delve into that more right now as it's not important to my original problem.
My concern is just getting data actually read out to the console from the flash. - Altera_Forum
OK, so what's the behavior right now? What's not working correctly? Have you thought about adding SignalTap to verify functionality or performing a simulation? Your code looks fine.
The test game won't boot onto the console. When I tie the LEDs to the FL_DQ lines I don't see any indication that they're going hi or low.
I haven't tried signaltap or sims yet, no. I've done this sort of thing with CPLD chips before with no trouble, but only controlling address and control pins - never with data pins. So that's why I'm hung up. It looks like it SHOULD work, but it doesn't. Any chance I need to things to high Z until the console boots? I tried that with using SNES_RST as an enable on all the FL pins but that didn't seem to do anything different either... - Altera_Forum
Well, then we have to start getting into I/O related stuff. What I/O standards have you set in the Pin Planner? What voltage are you using? Is anything working correctly at all?
Fixed it.
Didn't have the Data pins set to 'Z' when not being accessed. SNES_DATA <= FL_DQ when (SNES_ROMSEL = '0') else "ZZZZZZZZ"; That works properly. - Altera_Forum
Well, that explains why you had GPIO_0 as inout in the original code! Did you change SNES_DATA to inout? I'm guessing yes since you can't make an assignment to a port if it's an input.
--- Quote Start --- Well, that explains why you had GPIO_0 as inout in the original code! Did you change SNES_DATA to inout? I'm guessing yes since you can't make an assignment to a port if it's an input. --- Quote End --- No it's set as an Out only. I don't need to read from it right now, so implementation as an Out seemed easier anyways.
