9 years agoTrouble interfacing FLASH pins to GPIO (retro game related)
Hey all, Just got an Altera DE1 dev board using the Cyclone II, and I'm working on a simple test that is literally just connecting the FLASH chip to the GPIO_0 bus. I'm not performing any logic...
9 years ago --- Quote Start --- You have to create a SIGNAL assignment for an additional signal in the design. SIGNAL FL_ADDR_TEMP (21 DOWNTO 0); Then let's say you want to access address location 0x24ffff (22 bit wide address though your code isn't using any of the upper bits for some reason): FL_ADDR <= x"24ffff"; FL_ADDR_TEMP <= FL_ADDR; Then the code you have would be: GPIO_0(2) <= FL_ADDR_TEMP(17); GPIO_0(24) <= FL_ADDR_TEMP(16); GPIO_0(4) <= FL_ADDR_TEMP(15); GPIO_0(29) <= FL_ADDR_TEMP(14); GPIO_0(28) <= FL_ADDR_TEMP(13); GPIO_0(5) <= FL_ADDR_TEMP(12); GPIO_0(25) <= FL_ADDR_TEMP(11); GPIO_0(23) <= FL_ADDR_TEMP(10); GPIO_0(26) <= FL_ADDR_TEMP(9); GPIO_0(27) <= FL_ADDR_TEMP(8); GPIO_0(6) <= FL_ADDR_TEMP(7); GPIO_0(7) <= FL_ADDR_TEMP(6); GPIO_0(8) <= FL_ADDR_TEMP(5); GPIO_0(9) <= FL_ADDR_TEMP(4); GPIO_0(10) <= FL_ADDR_TEMP(3); GPIO_0(11) <= FL_ADDR_TEMP(2); GPIO_0(12) <= FL_ADDR_TEMP(1); GPIO_0(13) <= FL_ADDR_TEMP(0); --- Quote End --- Ok, so I have re-written my code to hopefully make things more clear. I have changed the data bus behavior to work as "read-only" from the Flash chip, so that should make things simpler to implement. However, this still isn't working:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity mapper_test is
port(
FL_ADDR : out std_logic_vector(21 downto 0);
FL_DQ : in std_logic_vector(7 downto 0);
FL_CE_N : out std_logic;
FL_OE_N : out std_logic;
FL_RST_N : out std_logic;
FL_WE_N : out std_logic;
-- LEDR : out std_logic_vector(9 downto 0);
-- LEDG : out std_logic_vector(7 downto 0);
-- SW : in std_logic_vector(2 downto 0);
SNES_ADDR : in std_logic_vector(21 downto 0); -- SNES ADDRESS BUS
SNES_DATA : out std_logic_vector(7 downto 0); -- SNES DATA BUS
SNES_ROMSEL : in std_logic; -- /ROMSEL (CART PIN 49)
SNES_RST : in std_logic; -- CART RESET
SNES_VCC : in std_logic; -- CART VCC
SNES_RD : in std_logic -- SNES /RD
end mapper_test;
architecture arch of mapper_test is
begin
--FLASH CONTROL PINS
FL_CE_N <= SNES_ROMSEL; -- INPUT SNES /ROMSEL TO OUTPUT FLASH /CE
FL_OE_N <= SNES_RD; -- INPUT SNES /RD TO OUTPUT FLASH /OE
FL_RST_N <= '1'; -- KEEP FLASH /RST HIGH
FL_WE_N <= '1'; -- KEEP FLASH /WE HIGH
--FLASH DATA PINS
SNES_DATA(7 downto 0) <= FL_DQ(7 downto 0); -- INPUT FLASH DATA BUS (7:0) TO OUTPUT SNES DATA BUS (7:0) FOR READ MODE
--ADDRESS PINS
FL_ADDR(14 downto 0) <= SNES_ADDR(14 downto 0); -- INPUT SNES ADDRESS (14:0) TO OUTPUT FLASH ADDRESS (14:0)
FL_ADDR(20 downto 15) <= SNES_ADDR(21 downto 16); -- LOROM CONFIG ---> INPUT SNES ADDRESS (21:16) TO OUTPUT FLASH ADDRESS (20:15)
FL_ADDR(21) <= '0'; -- KEEP FLASH(21) LOW FOR 2MBYTE ONLY
end arch; Any ideas of what else it could be? I figure it still has to be with the data bus, but I don't know how else to write it.
