sung_chul's avatar
sung_chul
3 years ago
Transceiver output characteristic
Hi-
1. Question
In Transceiver Native PHY Intel Arria 10/Cyclone 10 FPGA IP,
In 2GHz, Well done
But 5Ghz, 101010 Voltage Swing Very low voltage
below fig show 10101010 ans 11001100, 11101110
2. Question
In assignment editor, I have "Transmitter voltage swhing" amend to a different value
values 30 is OK!
16, 13 is OK!
But 1-8 is not okay.
This value is compile error(Quartus Pro 18.1)
I was not tested all values(1~31)
  • Kshitij_Intel's avatar
    Kshitij_Intel
    Hi Lee,
    1. It looks like, you are having insertion loss on your channel. Insertion loss generally increases with frequency. To overcome high insertion loss use pre-emphasis.
    2. During characterization 1-8 is probably not going to open the eye that's why we have disabled it.
    In general to get the better results, reduce the voltage swing & increase the pre-emphasis.
    Majorly 2 things effects on the insertion loss.
    1. PCB material
    2. Width of traces
    Also, please go through the guidelines.
    https://www.intel.com/content/www/us/en/support/programmable/support-resources/signal-power-integrity/signal-integrity-support.html
    Thank you
    Kshitij Goel
    • sung_chul's avatar
      sung_chul
      Hi K**bleep**ij
      Thank you!
      Your advice has been very helpful in understanding "Transceiver IP."
      Sincerely!
