15 years agoTip/suppornt on debugging a VHDL project on Altera
Hi
I have some experience on hdl coding, but none on FPGA debugging. (which does not necessarily mean the problem may not be in my HDL coding... ;) ) I´m facing a weird (imho) situation in which two signals are touched within an 'if' block. In simulation everything is doing fine, but when I got it programmed and running on FPGA, only one of them is touched. The piece of VHDL code is the following: flash_process(clk) begin if(rst='1') then ............ int_flash_en <= '0'; etcmiv_data_rdy_detected <= '0'; ............ elsif(rising_edge(clk)) then if (..........) then ............ elsif(......) then if(.....) then ..... else if((etcmiv_data_rdy = '1') and (int_flash_en = '0')) then etcmiv_data_rdy_detected <= '1'; end if; if((clk_spi_flash = '1') and (int_flash_en = '0') and (etcmiv_data_rdy_detected = '1'))then int_flash_en <= '1'; etcmiv_data_rdy_detected <= '0'; ........ ....... else ...... int_flash_en <= '0'; ....... The only places in code where these two signals (int_flash_en and etcmiv_data_rdy_detected) are touched are listed above. When running on FPGA, I got a positive pulse on etcmiv_data_rdy_detected, but int_flash_en remains untouched ('0'). I was supposing etcmiv_data_rdy_detected should only go down together with int_flash_en assertion. Is my assumption wrong? Can anybody help me with some light on that? I am using Quartus II 9.1 web edition and ModelSim Altera Starter Edition 6.5b. My FPGA is a CycloneIII EP3C25Q240C8N Thanks in advance Cristiano
