Timing Slacks inside Altera IP
Hi Omer1,
Please help to provide more information to help on clarify the issue.
I guess the a10_internal_oscillator_clock0 is a reference clock to EMIF IP.
Correct me if I'm wrong.
Any other instance that used same clock for the clock source in your design?
Is there any other instances that has been connected to EMIF IP?
Can you try to remove other IP and fit the EMIF IP first in the design?
Then observe if the timing violation is still there.
Adzim
Hi Adzim,
- The a10_internal_oscillator_clock0 is not a reference clock to EMIF IP.
The a10_internal_oscillator_clock0 is internal clock (which is an internal clock that I don't have the ability to affect), and all our ref clocks are from PINs.
2. I have other instances that uses a10_internal_oscillator_clock0 clock, like this block:
tod_sync_pll_altera_iopll_221_fsgzxmq:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|iopll_inst~dprio_reg
So is looks like the issue is not related to the EMIF IP, but to a10_internal_oscillator_clock0.
I see that not all these slacks are related to the EMIF IP, but all are related to "iopll_bootstrap".
For example:
tod_sync_pll:u_tod_sync_pll|tod_sync_pll_altera_iopll_221_fsgzxmq:iopll_0|altera_iopll:altera_iopll_i|iopll_bootstrap:iopll_bootstrap_inst|gen_pll_dprio.r_dprio_addr_in_use~RTM_1
To:
tod_sync_pll:u_tod_sync_pll|tod_sync_pll_altera_iopll_221_fsgzxmq:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|iopll_inst~dprio_reg
Attached an image.
I think we have an issue which related to the a10_internal_oscillator_clock0 (which is an internal clock that I don't have the ability to affect) and not to the EMIF IP.
