Timing Slacks inside Altera IP
Are there any warnings or issues shown for the EMIF IP since this appears to be referring to one of the IOPLLs for the EMIF in an I/O bank? What is your refclk for the IP and what speed do you have the EMIF running at (internal and external)?
Hi sstrel,
I don't see any warnings or issues regarding the se_phy_master.qsys (EMIF IP).
The refclk is 266 Mhz. The EMIF running with clock of 1066.667 Mhz.
Attached in image.
BTW - I see that not all these slacks are related to the EMIF IP, but all are related to "iopll_bootstrap".
For example:
tod_sync_pll:u_tod_sync_pll|tod_sync_pll_altera_iopll_221_fsgzxmq:iopll_0|altera_iopll:altera_iopll_i|iopll_bootstrap:iopll_bootstrap_inst|gen_pll_dprio.r_dprio_addr_in_use~RTM_1
To:
tod_sync_pll:u_tod_sync_pll|tod_sync_pll_altera_iopll_221_fsgzxmq:iopll_0|altera_iopll:altera_iopll_i|twentynm_iopll_ip:twentynm_pll|iopll_inst~dprio_reg
Attached an image.
I think we have an issue which related to the a10_internal_oscillator_clock0 (which is an internal clock that I don't have the ability to affect) and not to the EMIF IP.
