15 years ago
Timing problems?? help
Hi, I have a problem, I created a system in SOPC with Nios II, Sram, Switch, LEDs and a custom interface to an external component.
The custom component implemented in VHDL is linked to the system with NIOS in Quartus,
The clock is connected to the system is 50 MHz (DE1 board), the external component has a 2.5-MHz clock through a divider.
Timing problems that I see in the report, there are many paths not correct.
Timing analyzer -> Fast Model-> Clock Hold -> Not operational: Clock Skew> Data Delay -> From ... To .. Actual and Shorte P2P TIME
Timing analyzer -> Slowt Model-> Clock Hold -> Not operational: Clock Skew> Data Delay -> From ... To .. Actual and Shorte P2P TIME ecc...
How can I solve this problem?
Thanx.
p4ride
1 Reply
    I saw that nios_system and external component are not a problem of timing.
    I have problems connecting them.
    So are caused by the wrong interface, as I choose the timing parameters in SOPC Component Editor??
    Sorry for my english...
    p4ride.
