15 years ago
Timing error when storing result in RAM blocks using In-System Memory Editor
My design consists of some mathematical calculations (multiplications, additions,...). I supply the input using a RAM block and am trying to store the output using another RAM block. I use the In-System Memory Editor to read my output result.
Upon compiling my design, I got Critical Warnings stating 'timing requirements are no met'. I figured this is due to propagation delay between the input and output storage, since I am using the same clock for both, and I added a second clock for the output RAM block.
Re-compiling gave me the same timing error. So I opened up the TimeQuest Network Analyzer, went to 'Report Top Failing Paths' and added "Multicycles between clocks" to adjust for the time delay. I recompiled and got no timing warnings.
however, my output values keep on changing every time i refresh the instance in in-system memory editor.
I don't understand why this would happen. Your guidance and help will highly be appreciated.
    I suggest full rtl simulation of all design including RAMs in order to verify that the write/read logic is doing its job.
    I ran a ModelSim-Altera simulation to confirm that my output (of my computation logic) is correct.
    As you advised in another post, I added latency where ever necessary to try to minimize the path constraints.
    The problem now is that after adding some latency, and by trying to avoid using the Multicycle-approach, I keep on getting slacks at some path or the other.
    The weird part (at least to me) is that Quartus initially showed a slack in a path near the middle of the computational logic. Upon adding some latency/registers to correct for time delay near the middle path, Quartus then showed a slack near the starting of the design. And again upon correcting this slack using latency, a slack showed up some where in between the computation logic.
    Why would Quartus not start showing the slack from the top and proceed towards the end?
    Your post and mine were lost.
    What I was implying is that your thoughts on clocking and multicycle are not right.
    As to the solution, I think you need first to word(identify) the problem. It could be your output will not cycle exactly or your computation logic is buggy. I will put timing as last culprit if at all, check rtl simulation to exclude timing.
